Discussion topic: No Broadband
This message was authored by: LMGCarr33
No Broadband
We don't have any Broadband service although the checker is saying we do.  It's showing as no devices are connected.
Re: No Broadband
@LMGCarr33
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
▪️I AM NOT A SKY EMPLOYEE ▪️
