Discussion topic: No Broadband again
Message posted on 05 Apr 2026 01:10 AM
No Broadband again
Message posted on 05 Apr 2026 05:09 AM
Re: No Broadband again
@JamesSt82
You haven’t contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
