Discussion topic: New sky max hub
Message posted on 18 Jan 2025 07:13 PM
New sky max hub
The WiFi isn't working properly speed tests to the hub are fine but speed over the WiFi isn't terrible and not connecting to some devices
Message posted on 18 Jan 2025 07:15 PM
Re: New sky max hub
WiFi speeds are terrible
Message posted on 19 Jan 2025 07:22 AM - last edited: 19 Jan 2025 07:24 AM
Re: New sky max hub
@Kernowmogwi wifi signal strength is affected by the layout of your home and the type of construction your new hub is potentially a lot faster than older models but customersccan hit issues if the hub is not positioned properly which is as central in the property as possible and out in the open on a surfacecso its WiFi signal is not blocked by things like radiators. After that you may need some form of extenders which Sky will supply if you have bought their WiFi Max bundle see https://www.sky.com/help/articles/sky-wifi-max
If some defvicescwont connect reducecthe WiFi security level in the My Sky app from WPA3-T to WPA2.
