Discussion topic: New hub
This message was authored by: Stuart0071
New hub
I'm getting sky fibre on Tuesday next week I have had normal broadband with sky. Will I get a new hub box and when will it get delivered
Re: New hub
@Stuart0071 What sky hub do you have just now, see the pictures linked below if you are not sure! If you have the Sky Q Hub or Sky Hub then chance you will be, all others possibly not!
This message was authored by: Waveman
Re: New hub
It sort of depends on what you have now.
If you have a WiFi Max hub then you wont get a new one as this is what is sent out for new connections. If you go to your Sky Account, look under my orders and it will list the things that willl be happening up to your activation date.
If you have ordered GigaFast service they will send you their new GigaFast hub anyway for new fiber connections.
I remember the Internet starting!
Sky Full Fibre & Virgin Media XGS-PON, with automatic failover using DrayTek multi WAN router.
Sky Q, which will be sadly missed when they decide to kill it off!
