Discussion topic: New equipment
This message was authored by: Spooks
New equipment
Has anyone else had constant issues with their Internet going off? Sometimes its for an hour, sometimes a couple of hours, sometimes days.
I had the new equipment put in and its been awful.
The broadband WiFi checker most of the time says its connected fine. Im sat here now and its gone off again. 1.51am, it says connected without Internet.
Its incredibly irritating!
Re: New equipment
@Spooks
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If it isn't use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
Avatar for Spooks
Re: New equipment
That makes sense for last night.
Most of the disruption is during the day and it then goes off for days.
I think I'll ring sky. This was the option I was given when trying to find some answers.
Thanks for your help.
