Discussion topic: New connection problem
Message posted on 13 Jun 2024 07:58 PM
I've just got broadband super fast , have previously had broadband from sky
the old router was connected using a micro filter never had any problems
the new router and connection leads don't fit the micro filter so have plugged it straight into phone socket as per instructions but it is not connecting to the internet
id be grateful of any suggestions for how to fix this
Message posted on 13 Jun 2024 08:25 PM
Re: New connection problem
When did you join/upgrade .
If you are getting superfast via a fibre optic connection then you would have been sent out an ethernet cable/conversion kit
When is or was your activation date
Message posted on 13 Jun 2024 08:38 PM
Activated today
I've connected as per instructions
