Discussion topic: New Wi-Fi max hub
Message posted on 13 Apr 2025 10:24 PM
New Wi-Fi max hub
Only had it 2 days and it's very slow with the mobile phones and a PlayStation I need to Turn it off on my phone if I want to use WhatsApp quick or check my emails
Message posted on 14 Apr 2025 07:18 AM
Re: New Wi-Fi max hub
@Fizzy3 the WiFi Max hub has similar range as other Sky hubs so think about where it is. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Message posted on 17 Apr 2025 08:30 AM
