5
Discussion topic: New Broadband connection
This message was authored by SAGIMOH This message was authored by: SAGIMOH
Hi, Can any one suggest on how I can get a new Sky broadband connection ?
I do not see support contact number on site. So please help me here.
Kind Regards,
Mohan
This message was authored by Highlinder This message was authored by: Highlinder Answer
Re: New Broadband connection
@SAGIMOHLook at the bottom of this link says get in touch, it gives you a number when you jump through the hoops.
https://www.sky.com/help/home/broadband/join-sky-broadband/switching-to-sky-broadband/articles/switc...
@SAGIMOHYou can find a number to call Sky at the bottom of the link below under " Need more help ".
SAGIMOH
@Highlinder, Thank you for your help here !
I was looking for the sky contact number, so that I can call and discuss on broadband plans.
Still  I am unable to find their contact numbers.
Not sure how to reach out to a sky member and discuss about my new broadband connection.
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
@SAGIMOH
Dial 0333-759-1583 or if you're in ROI, the number is 08-18-50-019-2.
When calling, ignore the message at the beginning and stay on the phone as long as you can. If the system sends a text message and asks you to hang up, don't.
If asked for the reason of the call, just say speak to advisor or cancel, nothing else. Finally you should be put in the queue for an advisor.
"Sometimes, the only choices you have are bad ones, but you still have to choose"
SAGIMOH
Thank you !
