Discussion topic: Network issue
Message posted on 29 May 2026 10:50 AM
Network issue
Message posted on 29 May 2026 12:13 PM
Re: Network issue
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
Message posted on 29 May 2026 12:27 PM
Re: Network issue
I have the same issue. This is the second day and I've tried everything sky help say everything is fine, but nothing is finding my network- eg my network doesn't come up on my phone and my Alexa can't connect. I've tried rebooting everything but nothing seems to work. I cannot do the things I need to do online. PLEASE can I talk to an actual person??
Message posted on 29 May 2026 12:46 PM
Re: Network issue
@Jeanmc1 you can call Sky and if you do not engage with the bot your call should be routed to an agent. However you can do a lot yourself first check the lights on the hub when you lose connectivity and usecthischelp pagecfor next steps https://www.sky.com/help/articles/hub-lights-explained-start
