Discussion topic: Network connection
This message was authored by: Samantha108
Message posted on 12 Jul 2025 06:30 PM
Network connection
Network connection keeps going down. Tests say everything is ok but every 5 minutes the network loses signal
Message posted on 12 Jul 2025 06:41 PM
Re: Network connection
@Samantha108 You may wish to run the diagnostic and also the service checker.
Try running the line test here to see if any faults are found:
