Discussion topic: Network connection
This message was authored by: Lewy02
Network connection
I have lost my network connection
Re: Network connection
@Lewy02 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Avatar for Lewy02
I tried this but the system says all okay but the hardware says otherwise
Avatar for Lewy02
I did run it but I can't get the answer that my hardware is showing
This message was authored by: Basketcase75
Looking at the main list of most recent posts seems everyone has issues today. I'm sat watching my router have three green lights got down to two then a flashing centre orange and then back to three green for a few minutes at most then repeat all. But it's ok cos the sky website said it's all working as it should do
Avatar for Lewy02
I have disconnected everything at least once, my router is showing all green lights on, but my external devices do not show any WiFi connection when I run a speed test and the SkyQ box is showing no Network Connection.
I run the Sky software to check the connections etc and that comes up with everything is running normal.
Aaaaah
