Discussion topic: Network connection problems
This message was authored by: CarineFierobe
Message posted on 24 Oct 2024 06:38 AM
Too many network interruptions since a few days, can't connect at all now
Find out more
Message posted on 24 Oct 2024 09:29 AM
Re: Network connection problems
@CarineFierobe Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
