Discussion topic: Net issues
This message was authored by: Nayab2
Message posted on 18 Jun 2026 06:14 AM
Net issues
Hi good morning so basically the WiFi box is plugged in
all the lights are showing green
done the check here and it shows full connection but I can't use the WiFi
nothing is loading on the tv or phone and it keeps saying check Internet connection
this issue has been since yesterday morning (17/6/26)
Find out more
Message posted on 18 Jun 2026 06:58 AM
Re: Net issues
@Nayab2 try powering down your Sky hub for at least 60 minutes to get you a different connection at Sky's end which often clears these faults.
