Discussion topic: Need to change a installation address
This message was authored by: Jefferson1
Message posted on ‎13 Jun 2024 10:09 PM
For unforseen circumstances I've had to move from my address u was supposed to install at and was wondering could i get installed at my new address
Find out more
Message posted on ‎13 Jun 2024 10:24 PM
Re: Need to change a installation address
As this is a customer helps customer foru you will need to call Sky about this.
150 is the free number to use from a Sky Mobile phone otherwise under "Need more help ?" link at the bottom of the page on this link is the number to call Sky on:
When you do call say nothing when the bot speaks to you about what your call is about as it should then route you to somebody.
