Discussion topic: Need a plug to fit wifi box
Message posted on 20 May 2025 10:05 AM
I have ordered a wifi bok from you guys however there isnt anywhere for me to fit it as i havent got wifi plug and one needs to be fitted in i should be getting activiated on the 27th May
Message posted on 20 May 2025 10:08 AM
Plug for wifi box
I havent got a plug where to fit in a wifi box as my flat had been in a fire and ive ordered one of you guys and my activation is on the 27thMay so i need an engineer to fit this in please i can do from tomorrow at any time thanks.
Message posted on 20 May 2025 10:12 AM
Re: Need a plug to fit wifi box
@Mj2035 wrote:I have ordered a wifi bok from you guys however there isnt anywhere for me to fit it as i havent got wifi plug and one needs to be fitted in i should be getting activiated on the 27th May
Not sure what you mean by a wifi box? Do you mean a booster? A new router? Both of these would need mains power.
Are you getting broadband supplied by Sky? What exactly have you ordered from Sky?
Message posted on 20 May 2025 10:25 AM
If you have placed a broadband order & your activation date is the 27th of May then an engineer will attend to fit a connection point on that day.
Message posted on 20 May 2025 10:28 AM
Im getting a new sky router i ordered the fibre on for 25pound a month.
Message posted on 20 May 2025 10:36 AM
Ok thank you
