Discussion topic: Need Engineer
Message posted on 27 Aug 2026 12:19 PM
Need Engineer
I have been semt a nrw router but my tv etc is connected to the old one the old one is not plugged in !! I need an engineer ive tried forgetting the old one and adding new nothing is working
Message posted on 27 Aug 2026 12:26 PM
Re: Need Engineer
If you have used the option for your TV to forget the old network, does it not then mind your new one. If not perhaps rebooting it at the mains then trying again to get it to find your new wifi network.
Message posted on 27 Aug 2026 12:41 PM
Re: Need Engineer
Ive tried everything my new router is plugged in but cannot be found by any device i need an engineer 🙈
Message posted on 27 Aug 2026 01:33 PM
Re: Need Engineer
Are the lights lit as they should be on the new hub ?
Message posted on 27 Aug 2026 01:51 PM
Re: Need Engineer
Yeah everything is normal new hub lit up but cant find it anywhere !!
Message posted on 27 Aug 2026 01:59 PM
Re: Need Engineer
Have you tried rebooting it to see if your devices will then find it ?
