Discussion topic: Name resolution issues when using an ovpn connect
Message posted on 08 Oct 2025 02:03 PM
For work we use an OKTA authorised open vpn connection. Today my sky router was upgraded from the old grey one to a white sky max router which does everything perfectly except allow me to access URL's through the VPN.
The VPN connects fine, but all the sites behind it cannot be found and return an address not found error
I still have the old router and when I switch back , everthiung is available again.
Maybe I'm not expolaining it correctly, but after finally manage=ing to get to speak to a technical resource, I was told there was nothing they can do.
I feel that, given the above, This must be something to do with a default setting on the new router. Can anyone give me some guideance on what I can do here?
Message posted on 08 Oct 2025 03:02 PM
Re: Name resolution issues when using an ovpn connect
@dc197 the change between the old black hub's and the white hubs which is likely to cause the issue is to do with a change to the Sky allocates IP addresses. The white hub's by default operates on a basis of 8 customers shating a single IP4 address. This can upset some business VPN systems. Initially try simply enabling uPnP which switches the hub to a 1;1 share which often works UPnP set up
If it doesn't read tge post pinned at the yop of thecforum and complete the form somthe network team can switch off tge sharing completly.
Message posted on 08 Oct 2025 05:14 PM
Thank you for your help.
I tried what you said, enabled uPnp but the sharing ratio is still set to 8:1
Message posted on 08 Oct 2025 06:27 PM
@dc197 They say 24hrs to apply a possible change, switch your hub off, and none off that works then pinned post at the top off the Forum fill the form to get it adjusted!
