Discussion topic: NO INTERNET CONNECTION
Message posted on 03 Jun 2026 04:29 PM
I am not able to connect to the internet. I have unplugged and restarted router thing but it says connected to router yes connected to internet no
Message posted on 03 Jun 2026 04:35 PM
Re: NO INTERNET CONNECTION
@Rita33
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
Message posted on 03 Jun 2026 05:15 PM
It says streaming problem. No internet connection. My house alarm is connected to the internet and I am an elderly lady. Can someone come in and sort it out.
Message posted on 03 Jun 2026 05:21 PM
If you look at your broadband hub, are all the lights lit up, or are any out or even flashing ?
Message posted on 03 Jun 2026 05:27 PM
The internet light is not on. It sometimes flashes amber, goes green and then goes off. It has flashed amber but now nothing.
Message posted on 03 Jun 2026 05:30 PM
Give this line test a try to see if it finds an external fault:
Message posted on 03 Jun 2026 05:34 PM
Message posted on 03 Jun 2026 07:28 PM
Does it give you something to do for a potential fix, if not I would suggest calling Sky.
