Discussion topic: NO BROADBAND AGAIN!!!!!
This message was authored by: Brenda+hammett
My sky app says there are no issues with the signal,my sky stream on the other hand has a big blue screen which say NO INTERNET CONNECTION!!!!!!
Re: NO BROADBAND AGAIN!!!!!
@Brenda+hammett
Are you other devices working and showing as connected to your Wi-Fi connection, if so try rebooting your Sky Stream box.
If they are also down then the  first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
