Discussion topic: NI WiFi at all
Message posted on 05 Feb 2026 06:43 PM
NI WiFi at all
Restarted WiFi multiple times turned on and off yet says it's working when there's no internet light only intermittent orange flashing
Message posted on 05 Feb 2026 06:45 PM
Re: NI WiFi at all
@KatherineSnow
