Discussion topic: MyCloud drive connection
Message posted on 19 Apr 2025 04:17 PM
I have a MyCloud drive - it was working fine as backup via Time Machine but now showing as offline. I can see it in the Hub settings on ip address 192.168.0.4 but the troubleshooting guide from WD suggests I should set up a port - opening port 443 but i can't see how to do that. have tired all the other self-help options and this seems to be the only thing i can't address. it's not listed in the UPnP table.
Message posted on 19 Apr 2025 04:31 PM
Re: MyCloud drive connection
Is this what you have tried:
https://helpforum.sky.com/t5/Broadband-Talk/How-to-set-up-port-forwarding/ba-p/2662260
Message posted on 19 Apr 2025 05:19 PM
yes but i have a feeling i'm not doing it right - is the port value 443 or do i add the range 40000-49999? which are both value mentioned in the WD support video
Message posted on 19 Apr 2025 05:29 PM
Message posted on 19 Apr 2025 05:35 PM
Message posted on 20 Apr 2025 03:55 PM
so far what i've done hasn't worked
C
Message posted on 30 Apr 2025 10:58 PM
any other thoughts as to how i can get the WD drive back online?
Message posted on 30 Apr 2025 11:08 PM
Unable to see mycloud drive on network
