1
This discussion topic has been answered Discussion topic: My wiifi isnt working
This message was authored by: Rhian4
My wifi isnt working
Re: My wiifi isnt working
@Rhian4
Wi-Fi or broadband, they are different?
Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
@Rhian4
