Discussion topic: My wifi
Message posted on 08 Nov 2025 02:34 AM
My wifi
My wifi keeps cutting off like out of no wher completely stopped working have to reset the box and everything I do the checks on my sky it says no issue but on all devices shows and X or question mark next to the WiFi I reset the box and take 20 minutes to start working again it's a joke the amount I pay and it does this
Message posted on 08 Nov 2025 05:25 AM
Re: My wifi
@Gabby30
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it ~ it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
