1
This discussion topic has been answered Discussion topic: My wifi keeps going off
This message was authored by: holtrebecca87
Hi, my wifi keeps going off but evrrytime i do the service checker it always says it's fine when it's actively not working
Re: My wifi keeps going off
@holtrebecca87
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If it's not, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
@holtrebecca87
