Discussion topic: My wifi is not working
This message was authored by: Booster62
My wifi is not working and dropping. Looks like middle point is amber and the button on the side of the booster have no light. On the account says 1,7 mbs but no net.
Re: My wifi is not working
Hi @Booster62
If you are new to the forum then welcome to the Community which is predominantly made up of Sky customers helping other Sky customers. You aren’t actually talking to Sky by posting on here.
Broadband and Wi-Fi are different. Broadband is the internet connection provided by your ISP (Sky), Wi-Fi is the wireless connection between your hub and devices.
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault that just affects your address).
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
