Discussion topic: My sky pod speeds are slow
Message posted on 05 Jan 2026 08:14 PM
My sky pod today has been flashing white this evening and slow speeds is there a issue
Message posted on 05 Jan 2026 08:36 PM
Re: My sky pod speeds are slow
@Davey791 Yes flashing white is NOT what you want on the pod, so that is what you need to sort out now as your wireless wifi will be all over the place!
Message posted on 05 Jan 2026 08:41 PM
I rang sky but they said they couldn't find a issue but it's only happened tonight so I don't know if there is a issue with sky pods today
Message posted on 05 Jan 2026 08:47 PM
@Davey791 Flashing white on your sky pod, then are you sure the speed on it is not zero and you cannot and do not have a single device connected too it!
Message posted on 05 Jan 2026 08:51 PM
I have the device halfway between my router n pc but this evening I'm only getting 30 meg instead of 400-500
Message posted on 05 Jan 2026 08:58 PM
@Davey791 Not sure if you are getting what is said to you, flashing on the pod then it's not working at all! You should be able to see that in your app!
Message posted on 05 Jan 2026 09:01 PM
My bad sorry I misread when I rang sky it was flashing white they did tests and it's stopped flashing white but the speeds are terrible is it better if I go in the app and prioritize a device as I want my pc speeds the best it's currently set to sky stream
Message posted on 05 Jan 2026 09:03 PM
@Davey791 You can try that, have no idea what and how your system is setup!
Message posted on 05 Jan 2026 09:08 PM
I've left it set up how the engineer did it
Message posted on 05 Jan 2026 09:19 PM
@Davey791 Are you reluctant to change it?
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
