Discussion topic: My on-line is not working
This message was authored by: BuckA2003
I can't play online
Re: My on-line is not working
@BuckA2003
Do you mean your broadband isn't working?
If so and you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
