Discussion topic: My internet not working
This message was authored by: Peggy4
I have reset my Internet but it's not working at all on the Internet box. It's only two lights showing
Re: My internet not working
@Peggy4
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
@Peggy4 your hub has lost connection to the exchange. Check thst the issue isnt a loose connection tomthe ONT or phone socket ss appropriate. The online service checker in the My Sky app run over a mobile connection takes up to an hour to pick up that the hub has lost connection but it can tell you if Sky already know about an issue affecting your line if thry do it will be fixedcas soon as possible.
If however the fault is not known after walking you through some tests the app should offer to book an engineer. Alternatively you can call in oncecthe phone lines open after 8am
