Discussion topic: My internet is not working
Message posted on 04 May 2025 06:20 PM
Message posted on 04 May 2025 06:21 PM
Re: My internet is not working
@Stachulskadiana
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
