Discussion topic: My hub is not working
Message posted on 24 Mar 2025 10:30 AM
My hub is not working it's showing a red light with the voice and the Ethernet light is not working
Message posted on 24 Mar 2025 10:33 AM
Re: My hub is not working
@Bricey1
Message posted on 24 Mar 2025 10:35 AM
I have done this already there are no outages nearby has already run a test and come up with the same problem
Message posted on 24 Mar 2025 10:44 AM
Mine is the same somebody who say they are from Sky have just rang saying they can fix it? Put the phone down in case their scammers.Ran the test states no outages in my area ??
