Discussion topic: My fibre is going very slow
This message was authored by: Dodge161085
My fibre is only running at 60mbs when it should be at least 900mbs
Re: My fibre is going very slow
@Dodge161085
900Mbs would be the 'guarantee' over optical and ethernet cable as far as the Hub, not wirelessly from it.  If you are testing with a WiFi device then you aren't seeing the broadband speed.
