Discussion topic: My connection keeps going off
Message posted on 15 Jul 2026 09:06 PM
Internet keeps going on and off
Message posted on 15 Jul 2026 09:07 PM
Re: My connection keeps going off
@Lucie24
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
Message posted on 15 Jul 2026 09:09 PM
Thank you, I've done all the test, it was the same yesterday too
