Discussion topic: My broadband
Message posted on 28 Jan 2025 04:07 PM
My broadband
Message posted on 28 Jan 2025 04:54 PM
Re: My broadband
@Lukeharrowell
The lines may be busier than usual due to the damage and disruption caused by Storms Éowyn and Herminia which will also impact any potential Openreach visit.
Message posted on 28 Jan 2025 05:56 PM
Re: My broadband
Thank you but found out some delinquents have set fire to a telegraph pole and that's the issue
