Discussion topic: My broadband suddenly lost connection
This message was authored by: Jingles76
My WiFi went off whilst I was watching tv. I have done everything possible to see if it would reconnect plus I have checked with the on line to check my connection it says that everything is very good but I have got an orange light on my hub. I rely on the tv as I am disabled and the tv and Internet is my life line. I would be grateful if u could let me know what else i can do or what you can do your end please.
Re: My broadband suddenly lost connection
@Jingles76
Unfortunately we can't do anything our end as we're customers too.
It could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. If it hasn't returned by 7am use the below link to check to see if there are any problems or outages nearby
