Discussion topic: My broadband isnt working
Message posted on 29 Apr 2025 06:14 PM
My broadband is working i have two green lights one light is off and the other is orange.
Message posted on 29 Apr 2025 06:17 PM
Re: My broadband isnt working
@Martyn_d
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 09 Jul 2025 09:54 PM
Don't worry I've sorted it..
Thank you
Sharon Williams
