Discussion topic: My broadband help fixing it
Message posted on 04 Jan 2026 07:51 PM
I'm getting very angry! This sky broadband keeps losing my internet and switching off every hour! I need someone to fix it or look at the bt!!!
Message posted on 04 Jan 2026 07:57 PM
Re: My broadband help fixing it
@Laz
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
