Discussion topic: My broadband has not worked for 24 hours.
This message was authored by MGHB This message was authored by: MGHB
My broadband has been down since 6th October. I'm paying for a service I can't use and I need it to be able to work. Sky haven't even contacted me to explain why it's not working! Please can someone fix it and also compensation is required as I've not been able to use any of the services I pay to use as well!
Re: My broadband has not worked for 24 hours.
@MGHB
I believe you have to contact sky
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
Faults are not fixed unless you report it
@MGHB
Furthermore Openreach have two working days to fix once you report it. Thats OFCOM regs not skys
Below are skys compliance vis a vis aut compensation
https://www.sky.com/help/articles/auto-compensation
This message was authored by Daniel0210 This message was authored by: Daniel0210
@MGHB
Openreach don't work on domestic faults at weekends. Regarding the auto compensation, if you have a total loss of service and it isn’t fixed after two full working days from when you first report the fault to Sky, you will become eligible for it. It’s applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your account.
▪️ I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
@MGHB unfortunately as you will have read your assumptions on what happens when there is a broadband fault are incorrect something you are not only customer to.have as this comes up frequently. Sky customers are buying a package sold for domestic use which is significantly cheaper than business packages which come with higher service levels. As a guide a 12 hour/7 day SLA was recently quoted as costing £300 per month..
Few business ISPs will pro-actively contact the customer when the service goes down as simply there is often no way they can know a line is down as opposed to not being used until they are told.. Note the compensation scheme linked in earlier posts kicks  after 2 full working days from when you report the fault by calling Sky a forum post will not count as a report.
The fact you choose to use your connection for work is your choice but does not give you any priority. Sky are not unique all of the mass market ISPs have similar terms in their contracts. Millions of people do as you do and work from home but it is wise to have a fall back plan for the odd occasions when the line is down.
Hope you get your service back soon.
