Discussion topic: My WiFi isn't working
This message was authored by: Susieq1956
You say my WiFi is working but it isn't
Re: My WiFi isn't working
@Susieq1956
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
