Discussion topic: My WiFi isn't working
This message was authored by: SKYXJC2Y
I have no WiFi but the app is saying everything is ok.
Re: My WiFi isn't working
@SKYXJC2Y
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
