Discussion topic: My WiFi is not working and the box has no lights on.
This message was authored by: Amanda84
Amanda kitcher
my lights on my broadband box are not showing and I have no internet.
Re: My WiFi is not working and the box has no lights on.
@Amanda84 check its not an issue with the mains power supply to the Sky hub. If you can exclude that call Sky to report the fault they are likely to send out a new hub and ask you to return the faulty one. If your Sky Talk line is working dialling 150 on that gives you a free call.
