Discussion topic: My WiFi is down
This message was authored by: Arjan3
My WiFi is down
I need assistance as my wifi is currently down
Re: My WiFi is down
@Arjan3
The current heavy rainfall may be causing broadband issues.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
