5
This discussion topic has been answered Discussion topic: My WiFi has died since 8/7. Router still works with wired.
This message was authored by: AdamK5
I'm away and the hub WiFi just died on 8 July. I can still connect to wired devices. I've tried using the app to toggle the 2.4 and 5 bands off and on. Tried changing the WiFi PW and said then changing it back to original. Nothing works. Sky don't seem to have any human online chat and I'm not calling long distance. Can't they add a remote reboot to the **bleep** app? My old tplink was so much better. I only use this **bleep** for the land line.
Avatar for AdamK5
Level 2 icon
This message was authored by: AdamK5 Answer
Re: My WiFi has died since 8/7. Router still works with wired.
Not sure what fixed it but had another go with the app service checker, which said the WiFi was off, it let me enable it but although it still shows both channels off in the app hub settings it's now working. God knows why it went off.
Are you able to do these:
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
Avatar for AdamK5
Level 2 icon
I'm away and can't check stuff. Tried some of the test you suggested and it says I need to be at home to check the WiFi. It can't see any WiFi connected devices but all the hardwired ones.
Avatar for AdamK5
Level 2 icon
What I mean on the last sentence is that all my hardwired stuff is running fine, just WiFi devices are all disconnected.
Avatar for AdamK5
Level 2 icon
Avatar for AdamK5
Level 2 icon
Maybe the hub cooled down enough for it to start working?
