Discussion topic: My WiFi connection is down
Message posted on 08 Jul 2025 01:37 AM
My WiFi is not working iv tried following the steps to reconnect but it hasn't wirked
Message posted on 08 Jul 2025 05:35 AM
Re: My WiFi connection is down
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If your broadband still isn’t working after 7am use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
