Discussion topic: My Wi-Fi not working
Message posted on 30 Nov 2025 11:39 AM
Unfortunately my Wi-Fi not working
Message posted on 30 Nov 2025 11:50 AM
Re: My Wi-Fi not working
@Clara69
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
