Discussion topic: My Wi-Fi is not working
Message posted on 18 Nov 2025 07:29 AM
My wife is not working
Message posted on 18 Nov 2025 07:33 AM
Re: My Wi-Fi is not working
@Pollywollydoodl
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
