Discussion topic: My Internet is not working
This message was authored by: Matt+Oldham
My Internet is still not working. This is causing problems now with my family as we are using mobile data, we have no access to the Internet at all despite having a new router. I am now on the verge of leaving Sky as this is causing family arguments now and I can't work from home.
Re: My Internet is not working
@Matt+Oldham
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
@Matt+Oldham
Your duplicate thread has been removed to prevent unnecessary repeated replies.
