Discussion topic: My Internet is down showing no connection
Message posted on 05 Jul 2026 08:26 PM
since just now my internet is down and I have use your app to check there is no outage in my region, could you someone have a look at it ASAP?
Message posted on 05 Jul 2026 08:34 PM
Re: My Internet is down showing no connection
@sibi
You may not be aware but you haven’t contacted Sky by posting here. This is primarily a customer ▶️ customer discussion forum where we try to assist other customers.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
