Discussion topic: My Internet connection is not working
Message posted on 18 May 2025 05:30 PM
Message posted on 18 May 2025 05:42 PM
Re: My Internet connection is not working
@Eleonora
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 18 May 2025 05:49 PM
Thank you for the advice. Have followed all these instructions through my sky app, several times this weekend....and it now seems to be working.
But i've had this yesterday too, when it seemed to work for 5 -10 minutes and then the connection dropped again.
So fingers crossed !!!
Message posted on 18 May 2025 05:51 PM
If it continues you may need to call Sky.
