02 Nov 2024 12:44 AM
The other day while at work my wife messged me to say the Internet was down. When I got home i power cycled the sky hub and regained connection.
An hour ago the connection dropped again. Power cycled the router 4 times, the the sky broadband checker which initially says there's a fault, it then goes on to do the fix, everything on the broadband checker goes green and says fixed but still no connection.
Power light green, Internet light is dim green/off, WiFi light is green, voice is red/amber.
When plugging in my phone to the hub no tone, just a crackling sound.
This is on the 500mbs package with PON box.
There's not much else I can do at my end so I'm assuming either a cabinet issue or external?
02 Nov 2024 01:00 AM
Now instead of everything showing up green in the broadband checker it's now showing a fault but when trying to apply the fix after around 60 seconds I get the message:
Oops, that didn't work
We're having some problems and our tests are unavailable at the moment.
Try again later so we can test your connection
02 Nov 2024 01:06 AM
Sky broadband test is failing the hub connection test, then the fix times out with the oops message.
02 Nov 2024 01:13 AM
02 Nov 2024 05:44 AM
Posted by a Superuser, not a Sky employee. Find out moreTo get you some help with this I have escalated your post to the Sky Messaging team who should be in touch with you regarding this via a blue/red chat bubble which will appear at the bottom of this page. It can take up to a few hours to be contacted via this.
This isn't a live chat so replies are not instant.
02 Nov 2024 07:29 AM
I'm exactly having same issue from morning, first it said there's sky issue now it says the issue is resolved but my internet light is extremely dim. Tried the above method a few times but no success.
02 Nov 2024 08:34 AM
Posted by a Sky employeeHi there! Thank you for escalating this. We have sent an invite to @ronson12.
02 Nov 2024 08:37 AM
I also just woke up to no connection. The message says " sorry, because of s technical issue, you're currently experiencing a limited service. Please be assured that we're working hard to fix the problem "
02 Nov 2024 01:51 PM
Thanks for the reply. The service checker is now saying theres an outage and quite a few people in the area have the same issue.
02 Nov 2024 01:52 PM
I ended up calling customer service and got sorted
