Discussion topic: My Google devices won't connect
Message posted on 14 Jul 2025 09:05 AM
Message posted on 14 Jul 2025 10:45 AM
Re: My Google devices won't connect
@Clear+blue black or white router from Sky?
Message posted on 14 Jul 2025 12:37 PM - last edited: 14 Jul 2025 12:44 PM
Message posted on 14 Jul 2025 02:34 PM
It's a black router with no WPS button, which I don't like. I have managed to connect my google divices now.
Message posted on 14 Jul 2025 02:36 PM
Well, mine doesn't and in the help info it does mention some don't have the WPS button.
Message posted on 14 Jul 2025 02:38 PM - last edited: 14 Jul 2025 02:40 PM
@Clear+blue The wps if you have the Black SR203 hub is on the right hand side edge as you look at it from the front, and about 1 inch from the bottom! Same as the link with the white router pictured!
If there is none then there are none!
